Front Strut Issues
Old Aug 12, 2008 | 07:36 PM
juansantos's Avatar
Default Front Strut Issues
Hi Everyone.
I have a 2001 S80 with a wierd issue. On sightly bumpy roads the center console from the odometer to the glove compartment has a wierd shake, on big bumps it is load also. Also when I brake I feel as the car is gowing in a back and foward motion and it would create a grinding noise.
I honestly this that it is not the Shock absorbers due to the fact that I did the test of rocking the car up and down and after I get off it stops oscilating inmediatly, But when I try to oscilating it back and foward I get a gring noise.
I though it might of been the control arm bushings, but I repalced them with OEM bushing that I think might not be good quality but it still has the same noise.
Please help with some recomedations that I should do to reapir this issue.
Regards,
JS
Old Aug 12, 2008 | 09:45 PM
Default RE: Front Strut Issues
Engine mounts good?
Old Aug 13, 2008 | 07:57 AM
juansantos's Avatar
If I would have to change the engine mount, how much more or less would this be and what replacement part would I have to get.
thanks,
JS
Old Aug 13, 2008 | 06:29 PM
First check the upper torque mount. (Top of engine) Then check FCPgroton.com for prices.
nhadoulis
Mar 2, 2014 10:03 PM
RJSV70
2001-2013 model year V70
Dec 6, 2012 06:10 AM
rmarkd
Oct 31, 2011 12:02 PM
go2sharks
Jun 2, 2007 11:00 AM
960estateman
May 27, 2007 12:53 PM
