Fuel Injector metal cap and ring inside intake manifold
Old Oct 30, 2021 | 02:01 PM
kkresge's Avatar
Default Fuel Injector metal cap and ring inside intake manifold
I had to remove the fuel rail from my 2009 S80 3.2L engine to check one of the intake injectors that was reading an error. On removal one of the end caps fell into the intake manifold and I found the ring directly under the cap is broken (not completely but cracked)
My questions
1. do I need to somehow remove the cap from the intake manifold - any issues with leaving it there? (I did remove it by using a shop vac and a rubber hose - question is more for information purpose)
2. is the black cape necessary for the injector to regulate the amount of fuel being delivered (seems to be only a cap and would interfere with the fuel injector operation) - I tried to reattach it but no longer clips on and comes off very easy all others snapped on firmly.
After testing and cleaning all the fuel injectors and after install if the retaining ring (at least is what I'm calling it as it appears is their to keep the seal in place) if I remove the fuel injector again the ring will most likely fully break and fall into the intake manifold.
3. will that ring cause any problems if left in the intake manifold?
4.. is the ring a vital component and if it does break do i need to replace it? where can I get replacement parts for the fuel injectors
appreciate any advice
johnysmith
Jul 4, 2024 05:55 PM
Jono
Oct 24, 2013 09:57 PM
hillbilly
Oct 13, 2013 09:21 PM
shop2
Feb 16, 2009 06:30 PM
Volvo Penta
Penta
Dec 25, 2006 06:01 PM
