Fuel line removal
Old 11-07-2007 | 12:28 PM
Ricardo12's Avatar
Default Fuel line removal
How do you remove the fuel line going into the fuel pump?
How do you remove the fuel line going into the fuel filter?
Do you need a special tool?
What I see on the fuel pump is, the fuel hosegoing intoa plastic connection(or fitting) and the fitting connected to a plastic nipple coming out of the fuel pump.I do not want to break anything and any help would be appreciated.
Old 11-07-2007 | 09:35 PM
Default RE: Fuel line removal
There is little buttons on both connections you need to push in to release the hoses.
Old 11-08-2007 | 06:23 PM
Ricardo12's Avatar
Tech
Thanks. I found the button. It was located on the under side of the fitting.I looked closely at it when I pushedit and I could see the inside of the fitting opening.I have not pulled the fuel hose back and off. I think I can remove it now.
I am assuming the fuel line is under pressure.If I leave it sit for awhile will the pressure come down or is there a special way to relieve the pressure?
Old 11-09-2007 | 07:17 PM
It might drop some.
You could also push in the schrader valve on the end of the fuel rail CAREFULLY to releive the pressure.
tr_car_nut
03-24-2017 10:59 PM
smithnr
04-08-2013 05:56 PM
evbrad2002
04-04-2013 05:59 PM
CoVoVo
10-24-2012 11:19 PM
defuse
08-03-2005 10:41 PM
