Headlights problem
Old Feb 24, 2009 | 07:28 PM
xxxxdenis's Avatar
Default Headlights problem
My 1999 Volvo s80 has headlights problem they just went bad I cheek all the fuses and bulbs and still not working both sides are dead.
Thanks for any help
Old Feb 24, 2009 | 07:53 PM
JTapper's Avatar
Lose the low beams only? If you checked the fuse in the passenger compartment, AND the two under the hood, and they're all good it is probably the resistor shunt on the CEM. It's under the dash on the drivers side, left side of the footwell. The low beam one is the bottom one. It's about 1 1/4" wide by 3/16" thick blade looking deal with 4 prongs. Swap that one out with one of the ones above it (for turn signals). They're all the same. If you get lights, then you need to replace the bad shunt. They're available from the dealer for around $6. I believe it's part #9442190
Old Feb 24, 2009 | 07:58 PM
Maybe the shunt in the CEM went bad or is not making good contact.
They tend to burn and cause a bad connection.
Old Jul 10, 2013 | 12:07 AM
mdog1885's Avatar
I am having the exact same problem right now. I am going to check the shunts tomorrow. Thanks for the info guys.
AnEskimo
Oct 29, 2011 06:46 PM
VDriver24093
Feb 21, 2011 04:35 PM
mrjka
Feb 12, 2007 11:55 AM
acldrwd
Oct 14, 2003 09:25 AM
