heater core
Old Sep 25, 2010 | 01:00 PM
venture5858's Avatar
Default heater core
Core is leaking. Big repair, labor wise! I have disconnected in & out hoses to heater. Objective is to connect hoses to each other & bypass heater for time being. Like everything else volvo, connections are not standard anything! Plastic "spring" clip holds plastic connection in place. Connection has a lug that fits a slot on heater core pipe, so can't just shove a pipe into it & hose clamp it.
How much pressure is there on the fluid going into the heater core????? Can I cut the heater hose, insert a pipe, hose clamp it & then rejoin/replace the hose when I replace the heater core?
Old Sep 25, 2010 | 07:19 PM
You should be able to loop them together easily. I think the PSI is only like 10-15 going through the hoses. I have never checked the exact pressure.
ycartf
May 6, 2013 11:19 AM
netconcepts
Jul 15, 2008 07:14 AM
Awespishus
Aug 9, 2007 04:49 PM
haydenm315
Oct 18, 2006 11:08 AM
azeezn
Dec 12, 2005 10:50 PM
