help 1999 Volvo s80 transmission service required
usually, if it says tranny service required, it's not lying.
solenoids might be bad, clutch might be overheating or slipping, many things could be going on, I would need to know more to make any accurate assessment at all. are any emissions warnings coming on? how about drive slowly, service urgent??? you would also want to pull codes.
okay, then you need a new transmission. and possibly an O2 sensor or two. pull codes to make sure there aren't any lurking problems like MAF sensor or bad modules. then try to get a transmission in there as soon as possible. any misfire?
EDIT: unless you're certified volvo mechanic and have the proper tools, i would not rebuild, there are too many rebuilt trannys that don't work right on this car for some weird reason, you have to know exactly what you're doing.
are you sure ? plx dont throw this poor guy for a loop to waste money on trans flush when he may need a rebuild
1999 Volvo S80 2.9 L6-2.9L
Fluid - A/T: Testing and Inspection
Oil level, checking
WARNING! Avoid skin contact with transmission fluid.
Note! if the transmission is overfilled with oil, there may be operational problems. the oil must be filled to the correct level.
Note: Oil grade: Only ATF fluid, Dexron III (with G-license). Transmission oil, Volvo P/N 1161521-8 (1 liter container), 1161621-6 (4 liter container).
Checking the oil level
Note! Carry out the following check at an oil temperature of 85 ±5°C. Go to car communication function group 4. Select the digital display parameter. Select the parameter for the transmission oil temperature.
Preperations
-park the car on a flat surface
-apply parking brake
-let engine idle
-move gear selector to position P
-select each gear position, stopping for five seconds in each position
Note! Waiting two minutes before checking the level
Note! Cars with Geartronic gear selector assemblies: P-R-N-D-Man. Do not shift up in the manual positions. Cars with conventional gear selector assemblies: P-R-N-D-3-2-1. Stop for five seconds in each position.
Oil level/temperature
Maximum level hot: 85 ±5°C Minimum level hot: 85 ±5°C Caution! the oil must not exceed HOT Max WARNING! The oil is very hot. Use protective googles and gloves Caution! Is the oil above Hot Max? Extract approximately a half a liter of oil. Check the oil level. Continue extracting a half liter at a time until the oil level is below Hot Max. The oil level must be between MAX and MIN. The oil level must not exceed Hot Max.
Test drive the car
Note! After replacing the transmission oil/filter, the "Transmission Service Required" counter must be reset. Use VIDA vehicle communication to reset the counter.
again, please pull codes so we can confirm that your tranny is or isn't toast. i agree with him. don't go getting anything done till you know what's wrong. best of luck
hello I have a bad leak coming from my 04 S80 T6 (4 speed auto geartronic)
I know for sure that it is coming from the o-ring at the bottom of the transmission dipstick filler tube
(And no I did not over fill.... whoever worked on this transmission before screwed up)
is there anyway of repairing this without removing the transmission....
PLEASE HELP!!!!!!!
Thank You!
PLEASE HELP!!!!!!!
Thank You!
bradleyduncan
07-07-2011 10:32 AM
icehouse719
11-10-2010 03:31 PM
SusyC
07-18-2009 11:31 PM
chrissygm
09-30-2008 05:53 PM
