Horn and front lights stop working after small accident!!
Old Jun 17, 2018 | 01:15 PM
Tarik's Avatar
Default Horn and front lights stop working after small accident!!
Hi,
volvo s80 2007, message appears “light bulbs position failure” after small accident lights off, and horn stop working!!
Any body can help how can I fix the horn failure.
thanks in advance for time and efforts,
Old Jun 17, 2018 | 02:33 PM
did you check the fuses?
Old Jun 17, 2018 | 02:47 PM
Tarik's Avatar
Yes, I checked the fuses, and the front lights all are ok!! I don’t know are there any connectors behind the front bumper may damaged due to the accedent?
Old Jun 17, 2018 | 10:18 PM
well the horns are behind the grill/bumper so its quite possible the wiring or connectors were damaged. You'd need to go and test for voltage.
Old Jun 19, 2018 | 07:15 AM
tony1963's Avatar
I wouldn't do much diagnosing until the bumper cover and headlight assemblies are removed. You are going to have to inspect for physical damage and replace what is broken.
From what I see, you will need a bumper cover, both headlight assemblies, grill and maybe washer nozzles.
Old Jun 19, 2018 | 03:18 PM
Tarik's Avatar
Yes, you are right the horns damaged and I replaced both.
Still message “ pulbs position failure” comes on when I turn on the car.
TWR1980
Mar 12, 2025 07:34 AM
hiflier
Aug 9, 2018 09:44 AM
Gregman
Dec 29, 2012 01:20 PM
Volvofan0
Apr 22, 2010 09:45 AM
jfikentscher
Dec 3, 2005 12:04 AM
