How do you delete a text message?
I have a 2003 S80T6. It is over a year old. I want to delete a text message and cannot see in the manual how to delete the message. The message is
"On Call Plus Deactivated". This also causes the warning light /!\ to come on.
Is there any way of deleting the annoying message?
Also there is a leak of power steering fluid. I can't find it, but the reservoir needs refilling once every month. Has anyone had a similar problem?
Thanks for your help,
Troy Folkner
Troy Folkner
I will check on the message for you.As far as the leak check the hoses at the reservoir they are prone to leak there also check at the pump.If not there also check the metal lines at the steering rack the bolts on some of them weren't torqued properly causing them to leak.check those places and let me know.
I had a power steering leak also. I and the dealer could not find the leak....................the dealer changed every hose and etc. Finally the pump was changed and voila..............no more leak!! So...............ask the dealer to change the pump and perhaps your problem will be solved.
Moved from New Members Area. Due to its age I did not notify the original poster.
This post has been dug up after years, but the forum has changed with great members and I believe someone would be able to answer this question. I moved this to General Volvo Chat rather than the S80 forum, as moremembers can take a look at it.
JPN
JPN
ORIGINAL: TitaniumGreyS60
Wow no answers in years Holy crap.
I have the same problem....
Looks like I have to go elsewhere!
Good luck.
