How to Recharge A/C 2000 S80 T6
Old Jun 24, 2007 | 09:23 PM
Mike8502007's Avatar
Default How to Recharge A/C 2000 S80 T6
Is there anything special about re-charging the A/C on a 2000 Volvo S80 T6? I noticed that the easily accessable input at the front of the car is for the high side. The low side input is hidden down low under the power steering tank. With most air conditioners, you can simply fill up the system with a can of R134A on the low side. Right now the cold air from the vents ranges from 46 to 51 degrees and I would like to get it a little cooler. Any advice would be appreciated.
Old Jun 25, 2007 | 05:31 PM
Default RE: How to Recharge A/C 2000 S80 T6
You can add some from the low side.
But with not knowing how much is in there you could over charge and make it worse.
Old Jun 25, 2007 | 09:23 PM
thanks for your response. I guess the dealership must use the high side fitting with some kind of special equipment to charge the A/C which is why it is conviently located in the front and also why they hid the low side siding to prevent people from overcharging the system.
Old Jun 26, 2007 | 05:41 PM
Could be very possible.
These cars they wanted to have the charged from the high side.
Volvo Cars are very picky about the freon levels.
Jen Rosenblum
Apr 15, 2013 07:40 PM
ekanenh
Jul 20, 2011 05:34 PM
howardc64
Jun 16, 2010 07:40 PM
JBVolvo
Apr 6, 2007 04:48 PM
jcmartin
Aug 16, 2005 12:28 AM
