How to replace air mixture sensor?
Old Sep 20, 2005 | 12:03 PM
Majki's Avatar
Default How to replace air mixture sensor?
Hi there,
I would really appreciate if you can tell me where it is located (I guess somewhere on the air intake) and how to replace it. I have 2000 T6 model...
Thanks,
Majki
Old Sep 20, 2005 | 09:01 PM
Default RE: How to replace air mixture sensor?
Is it a big round sensor that looks like a hose goes on it?
Old Sep 21, 2005 | 12:31 AM
Majki's Avatar
I have no idea how it looks like! Somebody put a topic on this web site that when he replaced this sensor, it completely fixed his problem with his engine stalling; He initially cleaned his throttle body (which was not useful, and I agree, cause i did the same, as I have the same problem). The question is also how can i test the sensor if it properly works or not? I have voltmeter and I wonder if this sensor should give certain voltage when tested at different temperatures....
Thanks again...
(unfortunatelly i am just guessing here, it coud be thousand things...by the way, can i use injector cleaner to try maybe and fix the problem? My engine stalls only when idling (idling speed is 700 rpm); is there an injector cleaner for turbo vehicles?)
Old Sep 21, 2005 | 01:10 AM
Yes you can run injector cleaner through the system.
Im not sure if I know which sensor you are talking about. Maybe the Mass Flow sensor? But that usually affects the car totally not just idling.
qstyle
May 26, 2015 04:01 PM
fochs
Aug 19, 2012 11:26 AM
halo2maniak
Nov 15, 2008 08:28 AM
elchingon2002
Mar 11, 2008 10:41 AM
Lichty17
Oct 21, 2006 11:24 PM
