i need a part#
Old Jun 25, 2008 | 01:30 PM
silencecom's Avatar
Default i need a part#
i need the part # for the two vacuume check valves located under the intake manifold on 99 s80 t6. they are white and have about 1/2 inch sized fitting on each end.. they are installed in the vacuume list directly under the intake manifold and i believe they can be see with the intake manifold on... or one of them can be see anyway.. thanks!
Old Jun 25, 2008 | 06:41 PM
Default RE: i need a part#
Sorry so late but here it is 1275226
Old Jun 25, 2008 | 08:25 PM
silencecom's Avatar
thanks ..... now i wonder if i ordered the right part... they said they couldnt get just the check valves and that i needed to order the whole hose assy including both valves and the tubing at 76 dollars... it is the one that goes from the carbon cannister check valve to a T fitting.. then from the T fitting they both have a check valve and then one goes to the top of the intake manifold and the other goes to Y pipe that comes from the maf sensor.. does this sound like the part you are talking about? they are just simple check valves.... doesnt seem like i should have to pay 76 bucks for them and some rubber tubing.. the carbon cannister check valve im talking about is mounted to the radiator fan part# 9470775
Old Jun 25, 2008 | 08:36 PM
I would have to relook it up which I can't do right now. Also I don't remember seeing it when I looked the first time. But I know the Valves on the S40 should be the same. When we have needed them in the past thats what we had odered.
memphis
Oct 25, 2016 09:01 AM
Ryan Baker
Apr 19, 2015 12:03 AM
Kiss4aFrog
Nov 20, 2013 11:19 PM
sillygily
Jan 12, 2013 02:05 PM
Georgia Boy
Feb 20, 2005 08:30 PM
