Loss of power
recently I've noticed that my S80 doens't have too much power, after I step on the gas it take it a while to what it seems pick up pressure and then it'll go. I've had the transmission serviced, all seemed fine. There are no codes, no check engine lights, just a lack of power. I know its a heavy car but it never did this before. Also I've noticed that when I remove the shield from the bottom of the car, there is oil on it. the transmission was serviced and not leaking, the oil filter isn't leaking either, however there is oil on the bottom of the engince, not a huge leak but its leaving a little spot in my garage, is there somewhere I should look. The top of the engine is dry as can be, looks great actually. Please help!
I haven't tuned it up in about ayear, what would constitute as a full tune up for this car? I have changed the plugs, air filter, oil change. The oil seems to be coming from the back of the engine.
The Dealer will have to do it.
Your car should be under the Extended Warranty Volvo just put out. 10 Years 200,000 miles.
But you will need to have codes for it in the system. They will download software first to see if it fixes it.
It fixes 99% of them.
There was a post here on the forum.
If the throttle body goes bad it will get replaced under warranty.
If the car surges at idle and stalls take it in and complain about it.They will tell you upfront they might have to charge you a check out fee. But if it is because of the throttle body it will be done for free.
Give me some time to find the link and I will post it.
Or check with the Dealer for some Info.
Sparks plugs, is there any special type these 80's take? I have a 01 T6 and want to change to bosch plat +2 or+4 for increased spark. I've always ran bosch plugs. Do you recommend a spark plug to go in, or are we limited to volvo only plugs?
now you said it may be leaking from the vent box, where is this on the S80? it's starting to leak a bit more, but not enough to where I can tell on the dipstick or low oil pressure. Just can't find exactly where the leak is comming from. It just started in the fall and never stopped again... kinda annoying to tell you the truth.
Checked the vent box, completely dry, no oil to be found. Seems like the leak is comming from the back of the engine but can't find it. I'm going to try and degrease the engine, hose it off and drive it around till I find a leak. Any more ideas tech?
