Low Beam - Frequent Bulb Failure (09 S80)
Old May 27, 2016 | 09:13 AM
dusmith88's Avatar
Default Low Beam - Frequent Bulb Failure (09 S80)
2009 S80....Just replaced the Halogen bulb for the 2 time in less than a year. Drivers side low beam is frequently burning out? I read a little and wondering if this is a fuse issue, bulb issue, ballast issue...? Any ideas??
Old May 29, 2016 | 08:42 PM
brand of bulb? assuming you have standard H7 halogens not xenon HIDs I don't think you have a ballast. Also be careful not to touch the bulb part when installing - if oil (including from your fingers) gets on the bulb, it can heat up the bulb and shorten the life. Is the weather seal in good shape?
Old Jun 6, 2016 | 09:02 PM
thousandwords's Avatar
I have the same issue. I changed the low beam bulb probably 3 or 4 times so far in a little over 2 years. Honestly it did not bother me as changing the bulb is incredibly easy and a bulb every 6-9 months is not something that will break the bank.
Volvo_Neps
1998-2000 model year V70
Sep 12, 2024 06:53 AM
billveld
Sep 13, 2011 02:58 PM
Lolwilliams
Aug 1, 2011 02:47 PM
2005s60
Jan 19, 2011 01:50 PM
llcoollam
Apr 24, 2006 06:54 PM
