Low beam headlight bulb replacement
Old Dec 29, 2021 | 04:15 AM
Nakamoto's Avatar
Default Low beam headlight bulb replacement
Hello,
My dad’s 2004 S80 has a problem where the left lowbeam bulb flickers every few minutes. Besides this problem, I notice that about 4 seconds after I turn on the lights, there is some sort of motor that aims them way to low, reducing visibility by a lot - and causing a headlight bulb failure message to appear. Does anyone know if I can simply swap out the original bulbs for LEDs? Would this throw a computer error? And can someone please confirm if this model uses H7 bulbs for low beam?
Thanks!
Old Dec 29, 2021 | 07:05 AM
Do you have the Xenon bulbs in the low beam position? A D2R bulb instead of a H7? (2 types of headlamp assemblies are possible - but H7's usually don't flicker) If Xenon the D2R bulb moves up and down for high and low beam. The movement that you see is normal when first started. If still aimed too low, there is a manual adjustment.
The flickering (if Xenon) may be caused by a bad connection, ballast or a bulb. Swap left to right to determine which expensive part to replace. A Zenon bulb uses a ballast - there's no wire filament in the bulb - just gasses that produce the light. The ballast is #7 on the diagram, and there is a Chassis number break.
And if you use LEDs you will get a bulb out warning.
Old Dec 29, 2021 | 09:38 AM
Nakamoto's Avatar
Thank you very much for this information! May I ask what software you used for that diagram?
Old Dec 29, 2021 | 09:51 AM
That's a page from VIDA, Volvo's electronic service manual. You can probably find a theft-ware CD online on eBay.
Ayralynn
May 20, 2022 07:39 AM
Treman31
Aug 26, 2018 08:42 PM
jdsmith
Apr 11, 2009 03:03 PM
diehardgator1
Jul 23, 2007 05:57 AM
IKE8120
Dec 21, 2004 12:56 AM
