Lowering Springs ?
Old Sep 30, 2009 | 06:20 PM
cools80's Avatar
Default Lowering Springs ?
Anyone know if there is a 2" lowering spring for a 99 s80 ?
I am aware of the 1" to 1.5 but I would like to get 2".
Thanks for any help,
Old Sep 30, 2009 | 06:45 PM
solarman's Avatar
I was thinking of cutting mine to the same what wheel are on yours?
Old Oct 1, 2009 | 01:29 PM
cools80's Avatar
I have 19x8.5 with 235/35/19 it looks like plenty of room to go 2".
I was thinking of cutting mine also, but I would like a stiffer spring.
Guess I could cut a aftermarket spring .
Thanks, Allison
Old Oct 2, 2009 | 02:48 PM
frank17's Avatar
Does any one know a good website for coils, and what do u think about stock shocks on lowerd cars?
Old Oct 3, 2009 | 02:13 AM
kavith's Avatar
If you get lowering springs, I don't think the OEM shocks will wear out prematurely. A lowering spring under maximum compression shouldn't let the wheel get any closer to the vehicle than the originals, either way you're hitting the bumpstop. And the OEM ones should be able to handle that. However... the OEM ones will probably work rather crappily, since they will not give enough resistance to the wheel traveling.
I'd get the coilovers because then the spring rate and the shock rates have been designed by the same people to work together. Many lowering springs have recommended aftermarket shocks that go with them... but since that's not available for your car, coilovers will work better. If you want performance handling, install parts that work right.
ben10 games
rent wireless internet
Old Aug 6, 2023 | 03:43 PM
volvo-off-a-cliff's Avatar
you ever find any lol
Superfly
Nov 25, 2011 05:39 PM
xtrrtx
Suspension
Dec 5, 2006 12:04 AM
hauoli96734
Suspension
Aug 14, 2006 03:24 PM
hauoli96734
Aug 9, 2006 11:18 AM
ludeless
Nov 23, 2005 08:14 PM
