Misfire with Check Engine Light.
Old Jun 17, 2008 | 07:29 PM
EnzoRacing's Avatar
Default Misfire with Check Engine Light.
My wifes S80 has a terrible misfire. One Cylinder is definitely not running.
The Check engine light keeps flashing. How do i check to see what code it is?
What could the problem be? IS this a common thing with S80's?
It's a 2001.
Could it be a bad coil?
Old Jun 17, 2008 | 07:31 PM
Default RE: Misfire with Check Engine Light.
Bad coil or plug. Worse case burn't valve. But coils are common.
Old Jun 17, 2008 | 07:35 PM
EnzoRacing's Avatar
Good to hear.. IS the coil a dealer item only or can i get it elsewhere?
Old Jun 17, 2008 | 07:49 PM
You should be able to get a Bosch one (OEM) from places other than the Dealer.
Old Jun 17, 2008 | 08:37 PM
Tschadt's Avatar
Have Autozone read your codes, it will tell you what cyl. is misfireing.
akirk6884
Dec 24, 2010 10:29 PM
stanz
Aug 13, 2010 08:37 AM
theardentone
Mar 8, 2009 02:04 PM
ErnstlS90
Oct 23, 2008 08:37 AM
