multiple codes on '99 s80 T6
Old May 10, 2008 | 01:24 PM
  #21
charlesd's Avatar
Default RE: multiple codes on '99 s80 T6
Tech, I was hoping the problem was somewhere else. I will take it to a dealer and prepare for the worst. Thank you for your help. I'll reply back in a couple of weeks with the solutionwhen this gets resolve.
Old May 10, 2008 | 02:38 PM
  #22
Hope it is something that is pretty simple.
Old May 28, 2008 | 12:31 PM
  #23
charlesd's Avatar
Tech, I received the diagnosticcode sheet from my local Volvo dealer(who placed repairs in excess of ($5,000). The followingare present: ECM-1600, ECM4020, ECM9530, ECM5000, ECM8010 and ECM2000. My question is could a bad voltage regulator8010) cause the high signals on these other sensors(except the coolant temp sensor too low) or are they fuse protected?
Old May 28, 2008 | 05:37 PM
  #24
Not sure if it could.
What is it charging at?
Old May 28, 2008 | 07:49 PM
  #25
charlesd's Avatar
Tech, Thanks for your response. I don't know. I'll test it this weekend. I did retest the coolant temp sensor with engine on and at 80 degrees it'sshowing 3.7 volts. Still not reading temp. on the inst. cluster.
Old May 28, 2008 | 07:54 PM
  #26
Maybe there is something in the cluster that is burned out.
I wish I could help you more. But I am about out of ideas.
Old Jun 25, 2008 | 02:21 PM
  #27
charlesd's Avatar
Tech, I thought I would update you on my findings since the trip to the dealer. I decided to retest the voltage on the involved sensors. I found the coolant temperature sensor ground wire to the ECM was reading 11.5 volts(It's suppose to read low voltage as per VADIS). I began exposing and tracing the wiring and found several areas where cracked wire inside the heat protectant wrap had lead to contact to higher voltage components. While the heat loom was intact, wiring on top of the engine degraded. After separating the the wires in the harness and taping the damaged areas, the voltage at the ground wire reads 4.5 volts. This weekend I am going to expose the wiring to the other sensors and try to locate the short.
Old Jun 25, 2008 | 06:47 PM
  #28
Thanks looks like you are tracking it down slowly.
trooperone
Oct 14, 2010 05:47 PM
ckevg
Mar 19, 2010 08:45 PM
Old Blue 66
Sep 23, 2009 04:34 PM
Limon
Apr 6, 2009 08:08 PM
bluetank
Nov 2, 2006 10:21 PM
