need Blower motor help
1. Pull the passenger's side door sill trim straight up and remove it from the vehicle.
2. Undo the two screws and pull the passenger's side lower facia panel downwards and to the rear.
3. Slide the passenger's seat as far as possible to the rear, then rotate the fastener 90 degress counterclockwise and pull the center console side panel rearwards.
4. Remove the passenger's side glovebox:
A. Undo the two screws and pull the facia panel rearwards to remove it.
B. Open the glovebox, slide the two hooks past the tabs, and release the strut or return mechanism from the lid.
C. Undo the eight screws, and pull the glovebox from the facia, disconnect the light unit as it's withdrawn.
5. Release the floor carpet at the front edge and fold the carpet rearwards.
6. Working through the glovebox aperture, disconnect the blower motor wiring connector.
7. Undo the five screws and remove the blower motor from the heater unit.
8. If required, squeeze together the sides of the cover to remove it, then undo the two Torx screws and separate the fan and motor from the cover.
