Need help: '99 S80 with code p0036
Old Jul 18, 2012 | 01:40 PM
dockurty's Avatar
Default Need help: '99 S80 with code p0036
I am attempting a fix-it-myself, but my research shows that this is a "bank 1 sensor 2". Am I correct in assuming that it is the post-catalytic converter sensor for cylinders 1-3? Someone suggested replacing "both", but I am not sure if that meant both bank 1 sensors or both post-catalytic converter sensors. Any help would be appreciated. I have been fearful of doing work on this car, but it is getting old enough that I can invest less in repairs by doing it myself and not feeling as if I am feeding a horse that won't run.
Should I avoid Bosch's downstream/upstream/or universalsensors?
Thanks for any assistance.
Old Jul 19, 2012 | 09:45 PM
akabond's Avatar
this is what i got from Chilton Library site but its for 2000 S80:
Bank 1, Sensor 2
-Before servicing the vehicle, refer to the precautions.
-Raise and safely support the vehicle.
-Remove the lower engine cover.
-Disconnect the heated oxygen sensor cable harness above the sub-frame.
-Disconnect the cable harness from the SIPS member.
-Remove the screw for the cable harness clamp in the three-way catalytic converter.
-Remove the rear heated oxygen sensor. Use Proper tool.
To install:
-Install the rear heated oxygen sensor. Tighten to 33 ft. lbs. (45 Nm).
-Reconnect the heated oxygen sensor cable harness above the sub-frame.
-Reconnect the cable harness from the SIPS member.
-Install the lower engine cover.
-Reconnect the cable harness clamp in the three-way catalytic converter. ----Tighten the screw.
marc sanders
Feb 28, 2014 08:12 PM
Sanel30
Feb 18, 2010 09:16 PM
chef
May 19, 2009 05:57 AM
Pete 5
Sep 23, 2008 06:36 PM
tensai
Feb 28, 2007 11:01 PM
