Need to remove shift cable
Old Mar 2, 2010 | 11:59 PM
tboard24's Avatar
Default Need to remove shift cable
Lately I've been having trouble with not being able to remove my key or shift out of park. With the help of this forum I found out it was because the shift cable was probably gummed up. This is definitely the case, and as you can see from the pictures attached, this area definitely needs a cleaning. I want to remove the cable this weekend but I don't know how to get it out. Any suggestions? Thanks, -Tucker
Attached Thumbnails Need to remove shift cable-img_0060.jpg   Need to remove shift cable-img_0061.jpg   Need to remove shift cable-img_0062.jpg   Need to remove shift cable-img_0063.jpg
Old Mar 3, 2010 | 07:52 PM
In the second pic where the cable attaches to the shifter remove the cable and clean and lube the arm. That should fix your problem. The yellow part will slide then the cable will come out.
Old Mar 4, 2010 | 01:50 PM
tboard24's Avatar
So I just slide off the yellow part and the cable will come out?
Old Mar 4, 2010 | 09:11 PM
You slide it out some. It will not come all the way off.
Then only the cable will slide out of the shifter assembly only.
Old Mar 7, 2010 | 02:50 PM
tboard24's Avatar
Well in trying to slide it out some I broke the yellow plastic piece. Now the cable isn't attached to anything and the car can shift into any gear without pressing the brake. I need to get another of those yellow pieces ASAP! Does anybody have the part # and/or know where I can order one? Thank you, -Tucker
Old Mar 8, 2010 | 09:18 PM
9181002 should be the part number for it.
Old Mar 14, 2010 | 05:31 PM
tboard24's Avatar
Can't seem to find it anywhere. What website can I order it from? Thanks
Old Mar 16, 2010 | 09:37 PM
I think only the Dealer.
TheSenator
Oct 14, 2015 08:23 PM
Woober
Sep 28, 2014 10:18 PM
t-bone1924
Nov 28, 2012 11:01 AM
Annihilator
Feb 10, 2011 08:59 AM
reg
Jul 19, 2010 07:58 AM
