S70 w/ Broken Gear Shift Cable?
Old Feb 9, 2011 | 01:49 PM
Annihilator's Avatar
Default S70 w/ Broken Gear Shift Cable?
I am thinking about buying an S70 with what the owner claims to be a broken shift cable. He says it won't start because the car doesn't sense that its in park or neutral. He says he can move the shifter up and down as well. I did see a thread or two about that cable donut popping out of the mount but not sure if that's the case here. What do you guys think?
Old Feb 9, 2011 | 05:51 PM
It's likely the cam sensor.
Old Feb 9, 2011 | 05:57 PM
TonyClifton's Avatar
Gear Shift Cable? Interesting...
Check this site: out http://www.swedishautoparts.com/S70/...d-gaskets.html
Diagram looks very detailed.
S70 1999-2000 Gear Shift Cable OES 8689443 $ 115.35
fcpgroton's Avatar
Former Sponsor
rspi sounds like he is on the right track. Does the car have any codes?
Old Feb 9, 2011 | 07:18 PM
It doesn't crank at all. If that helps.... he claims his dad is a mechanic and stated the shift cable broke off in the trans... I'm used to GM transmissions so I don't know if that's plausible...
Old Feb 9, 2011 | 11:00 PM
Could be anything. How much does he want for it?
Old Feb 10, 2011 | 12:41 AM
$800. It has 140k on it and he is unsure if its a turbo. Body is pretty good. Leather is worn in spots....
Old Feb 10, 2011 | 08:59 AM
$800 Is not a bad price unless it has body damage. If it's a GLT or T5 it is turbo. Try to get him to split the tow and go for it. Tinker with it to get it running then decide if you will keep or sell it. If you get it running you can get $1,500 for it easy.
puroak
Oct 18, 2015 02:29 PM
TheSenator
Oct 14, 2015 08:23 PM
MDUBBSS70
May 28, 2014 09:02 PM
Captain
Dec 6, 2007 11:55 PM
