New Computor?? HELP!!!
Old Feb 24, 2011 | 01:44 PM
kennedy64's Avatar
Angry New Computor?? HELP!!!
I own a 2000 Volvo S80 T6 Turbo. Last summer, the transmission began getting stuck in 3rd gear if I used it in regular drive mode. If I use the "auto-shift" mode, it works better. In December, I drove the car home; two hours later it wouldn't start. So, the mechanic came and got it and diagnosed a dead "Camshaft Position Sensor". So, last Saturday he picked one up and installed it. Same problem; it wont start. So, he called today and I guess I need a new computor.
The price is $1,200, PLUS the cost of the software AND the 1/2 hour to program it. Does this $1,200 seem right? Will it "cure" the shifting problem, along with the check engine light? Oh, BTW, last year, I got stuck in a driveway due to ice. After an hour of trying to get "unstuck", I was so pissed, I got out of the car and slammed the drivers door. Hard. When I turned back around, I thought I would see a broken drivers-side window; nope! The side air-bag had deployed! Is THAT normal? Thanks for any input/advise you can give me.
Old Feb 24, 2011 | 02:24 PM
jlewisinsyr's Avatar
Is this a Volvo mechanic/dealership or just a local shop?
The airbag issue sounds really familiar, were you registered under a different name before? As for slamming a door while the car is running, yes, if you slam it hard enough, it could deploy the side airbag. Chalk that one as a lesson learned in anger control.
Old Feb 24, 2011 | 02:45 PM
kennedy64's Avatar
Hi, and thank's for replying.
He's a local guy who does really thurough work, but, no, he doesn't work for a Volvo Dealership.
And, nope, first time here. When I contacted Volvo last year, they didn't believe that just slamming a door would deploy the side air-bag.
Old Feb 24, 2011 | 08:26 PM
My concern with people who are not trained on Volvo's, they often misdiagnose electronic issues.
Old Feb 26, 2011 | 12:47 AM
JDusza's Avatar
Just passing through and I see transmission lock up followed by no start.
I own an S60 and just went through these symptoms.
Started with transmission service required soon, tranny stuck in 4th gear, ABS service light followed by the complete shutdown.
This all occurred over the span of about 3 weeks.
Volvo service identified it as arcing within the TCM connector. The harness side was reterminated and the TCM side was cleaned.
About 1 month in with no problems.
Best of luck to you!!!
SHBazTBone
Apr 18, 2014 04:25 AM
thexc90man
Mar 10, 2014 06:24 AM
hotheads1
Jul 10, 2011 09:00 PM
mrdjflores
Jul 10, 2010 02:38 AM
silver ghost
Mar 10, 2010 09:08 PM
