No fuel pressure! Relay? Pump? switch? wuh?
Old Nov 5, 2007 | 07:00 PM
Lab_Rodent's Avatar
Default No fuel pressure! Relay? Pump? switch? wuh?
I just got an S80 and havent gotten my manual for it yet. Went to start it today and I got no fuel pressure. Fuel pump doenst even turn on. Can you acces the fuel pump through the trunk? Anyone know where the fuel pump relay is? I get a high pitch electronic whine from the front of car during the time the fuel pump should turn on.?.
Old Nov 5, 2007 | 08:05 PM
Default RE: No fuel pressure! Relay? Pump? switch? wuh?
You have to remove the R/R seat back to gain access to the fuel pump.
But the wiring you can test is under the rear seat on the left side. There is a Grey plug with I believe 4 wires. I forget which one is the feed but if one lights for about 3-5 seconds then stops it is the wire.
spidersilva
Aug 17, 2011 07:23 PM
Mummymanchester
May 19, 2011 01:16 PM
TeaEye
Sep 16, 2010 06:16 AM
Joshbaldwin
Jan 15, 2009 06:35 AM
