odometer light
RE: odometer light
The cluster needs to be pulled out.
Then the bulb can easily be replaced.
There is a couple of screws holding the black part infront of the speedo assembly.
Remove the screws and pull the cover out.
Then there is 4 screws holding the speedo assembly in. Remove them and slide the assembly out and remove the bulb.
it is a regular bulb. Some of them the bulbs are soldered in and others the bulb pulls out.
Volvo850Rookie
12-09-2013 01:55 PM
blackcomb1
12-09-2012 12:39 PM
