oil leak
Old Feb 27, 2008 | 04:14 PM
JPizano23's Avatar
Default oil leak
Okay, I've got a leak comming from the area around my spark plugs. i think when I was changing the plugs a while back I loosened the wrong bolts and broke a seal or something because now that area around my plugs slowly fills with oil. it's not a huge leak, I lose about 1/2 a quart in between oil changes, but it does leak behind my engine and on the exhaust and it smells like burnt oil from time to time. What seal did I break? what is it going to take to fix this? Any insight would be great
Old Feb 27, 2008 | 06:49 PM
Default RE: oil leak
Are you sure it isn't from the oil cap seal?
Old Feb 27, 2008 | 07:54 PM
JPizano23's Avatar
I actually got a new oil cap seal when i replaced the PCV box and there wasn't any change. I cleaned up all the oil once and it filled within a week, most of it occurs near the oil fill. Very strange
Old Feb 27, 2008 | 08:05 PM
Does it fill the spark plug hole only or the top section?
Old Feb 28, 2008 | 10:30 AM
JPizano23's Avatar
it fills the little indentations around the spark plugs, doesn't actually fill the plug holes
Old Feb 28, 2008 | 06:24 PM
Then it has to be something else unless you can see it come out of one of the bolt holes.
Old Mar 3, 2008 | 12:18 PM
JPizano23's Avatar
I'll try cleaning the area and see if I can see oil comming from any specific bolt hole. If I find oil from a bolt hole what will a repair consist of?
Old Mar 3, 2008 | 06:51 PM
Then either try some sealer or the Cam cover will have to come off then resealed.
ROBLU540
Feb 20, 2009 07:59 PM
mkelly85
Jan 31, 2008 02:05 AM
pleonard
Jan 7, 2008 06:12 PM
jeannelw
Nov 18, 2005 10:05 PM
witstaffy
Jul 25, 2005 09:31 PM
