P1175 & p1237
Old May 17, 2009 | 02:34 AM
gordon368's Avatar
Default P1175 & p1237
Check engine light is lit up solid, and my obd ii picked up the codes P1175 & P1237.
As far as I can tell I looked it up and it says P1175 is missfire?
and for P1237 is related to the turbo control valve? or could it be a vacuum leak?
Old May 17, 2009 | 01:56 PM
ceepyou's Avatar
According to http://www.volvoforums.org.uk/showthread.php?t=42231:
"P1175 Cam Control Fault...
P1237 Fuel Pump Secondary Circuit Malfunction"
The user claims fault codes are applicable to all P2 models. Anybody else, please feel free to correct me if I am wrong.
Old May 18, 2009 | 09:07 PM
gordon368's Avatar
thanks for the reply, Are these expensive fixes?
Old May 21, 2009 | 10:44 PM
s70_t5_1999's Avatar
p1237 is the turbo control valve, the other is fuel adaption (caused by the TCV)
Old May 22, 2009 | 09:40 AM
gordon368's Avatar
turned out to be the control valve and a oxygen sensor O.o,
Thanks again
Old May 22, 2009 | 10:13 AM
vegasjetskier's Avatar
Any idea why the codes Creepyou quoted were inaccurate? Are there different codes for each car model? Where can we get a list of the correct codes?
Old May 22, 2009 | 10:39 PM
i get mine from this site:
http://www.iequus.com/support/obd2_definitions.php
they have volvo-specific definitions
Old May 22, 2009 | 11:01 PM
ceepyou's Avatar
Sorry about that. I hate leading someone in the wrong direction. That is why I asked to be corrected because two opinions are generally better than one. Too bad mine was way off. Thanks for jumping in s70_t5_1999. That is a good site and I will be sure to use that.
Old May 24, 2009 | 07:38 PM
gordon368's Avatar
hey I appreciate the help, but now for some reason two days after driving it the check engine light is on and the code p1175 is back ....
that is a great site the code one, looks like it says fuel adaptation bank 1, which means another 02 sensor i am guessing.
thanks for all the help
Old May 25, 2009 | 12:57 PM
ceepyou's Avatar
Matthew's Volvo Site says:
"P1175 ECM-260A Long-term fuel trim, Lower Limit"
An s60r forum also said the same thing and they claim that it was from VADIS itself. Maybe someone who has VADIS can double check or if there is a page on this site that has cross references, we can look into that.
From the research I have been doing, your o2 sensors could be a problem or it could be the MAF is defective or dirty, or your injectors could be clogging up on you or leaking. Have you changed the oil recently? Could it be contaminated or at too high of a level? (Unlikely) That is all I can find on the issue so far. I'll keep looking and let you know if I find anything more solid.
Old May 25, 2009 | 02:48 PM
ceepyou's Avatar
I am not sure what year your S80 is but I have a 1999 and these are what Amazon has for front and rear o2 sensors right now. I paid $30 more for the front so these are great deals. They seem to fit up to 2004.
Front:
http://www.amazon.com/Bosch-17036-Ox.../dp/B000BZL0LW
Back:
http://www.amazon.com/Bosch-16198-Ox...=pd_sim_auto_1
EDIT:
This does not mean that I feel it is your O2 sensor over any of the other possibilities. This is in case you decide to buy another sensor, you have a link of OE Bosch sensors at the best prices. From what I have seen, O2 sensors throw a P01xx code, not a P11xx code. Again, I am not as experienced as Tech or the other moderators so if they can pitch in (other members too), it would be great.
Old May 25, 2009 | 09:21 PM
gordon368's Avatar
i think i can rule out the mass air flow b/c it was done 10~ days ago (replaced). Oil change was done 3000~ mile ago.
Im guessing it was o2 sensors b/c that code came up last time and thats what it turned out to be !..
thanks dude
Old May 30, 2009 | 03:19 PM
gordon368's Avatar
new codes are back..
p1175 and p1238.
In addition my Mass air flow piece seems to be not working correctly. Could it go bad with in a month?
Old Jun 1, 2009 | 12:31 PM
gordon368's Avatar
turned out to be the engine control module had corrosion on it, and they cleaned it and said if it came back that I would need a replacement. This explained my stalling out randomly, and the intermittant funny type surge he said.
black99s80t6
Sep 11, 2012 09:37 AM
milbro40
Jul 26, 2011 09:45 PM
etype38
Oct 3, 2009 08:39 AM
ramp
Aug 31, 2006 11:24 PM
