Part Number for EVAP Cannister J-Hose?
Old Apr 12, 2011 | 03:37 PM
erndawg's Avatar
Default Part Number for EVAP Cannister J-Hose?
I have a 2000 S80 T6 2.8L that's throwing a P0442 "small evap system leak" code.
Can anyone tell me the correct part number for the J-Hose that connects to the Evap cannister?
From reading the posts here, that hose sounds like the most likely failure (crack or split in the hose).
But I see at least 6 different part numbers for the hose, and don't know which is correct.
Thanks for your help.
Old Apr 14, 2011 | 01:20 PM
erndawg's Avatar
Answered my own question, and for anyone else who may need it...
The J-hose is part number 1270255. (about $20+)
And if you're throwing a P0455, and it's not from your gas cap, check the EVAP purge valve located on the radiator shroud. It is part number 9470775. (Close to $40.) Don't forget to change the two small (~ 3 inches long) EVAP hoses connected to the purge valve. They are 5/16" or 8mm fuel/evap line.
Clacquam
Oct 25, 2014 08:52 PM
willseph
Jul 31, 2012 03:48 PM
4l41n
Jun 26, 2012 01:07 AM
The Viper
Sep 17, 2011 12:21 PM
Dainos
Dec 1, 2007 05:52 PM
