Passenger side view mirror cracked
Does anyone know if I will be able to replace a shattered side view mirror, without having to purchase an entire new side view mirror assembly? Only the mirror is cracked. Is it possible to purchase just the mirror and clamp it on? It is a 2001 S80 T.
Thank you.
Thank you.
It looks like the make it as a seperate part number:
http://www.trademotion.com/partlocat...layCatalogid=0
So that is a good sign that you should be able to order it right from Volvo. I would guess, $60 or so dollars (I think that is how much my Lincoln's was to replace with the heated mirror element).
side view mirror reply
thank you for your reply. it was very kind of you. i actually found that website when I googled for side view mirrors. just was not sure if i would be able to just replace the mirror part, or if it would require replacing entire assembly. hopefully, i will be able to just snap on a new one....best to you.
passenger mirror replacement
NBender....
I just ordered this exact part...wife hit it on the garage on the way out. It was $86.47, factory new...try this guy, Joe @ ebayparts@volvo-oc.com
I have ordered many parts from him...from headlights to cup holders...
The old one "peels" off, if you have heated mirrors be careful as there are 2 plugs on the back side...the mirror has the female connection on the backside if I remember correctly...you'll want to pull it off slowly. the new one will go right back in place...
Good luck.
Good luck.
Just replaced mine last night with the one I ordered from the guy I recommended...was very easy. pushed the mirror all the way "in" and the plastic frame popped right off and after a light messing with, the other popped right back on...pretty easy...there is an answer on fixya.com to help with a little more detail on the "how to" portion of this post...good luck
haha it was just temporary. Being from Canada i keep travelling back and forth to US so hardly get anytime. But in mean time my parents are driving it so i hv only temporary pasted a glass from an Auto Glass shop. Oh yes i will have to change the whole unit. Its also expensive and i am finding the right color too. So still shopping around
louigi
06-21-2011 04:09 AM
