PLEASE HELP Coughing Volvo
Old May 25, 2011 | 10:27 AM
Bimmerguy's Avatar
Default PLEASE HELP Coughing Volvo
Re: 2001 Volvo S80 T6
Thanks for reading, Every once in awhile my car starts with a cough so bad it's not driveable, I thought it was my ETM so everytime I cleaned it, it started up nice and smooth and ran smooth, now when it starts coughing I just disconnect the battery and the car runs great for a few weeks... Can anyone please tell me what's going on? I've installed new MAF, new Plugs new fuel filter.. the only error code I get is P1152 which kind of points to a ETM. whatever it is disconnecting the battery seems to fix it..Thank you in advance for any advice.
Old May 25, 2011 | 03:48 PM
tony1963's Avatar
It is NOT the ETM. P1152 points to a failed oxygen sensor, front, bank #2. The T6 is engineered systematically as two 3-cylinder engines bolted together. Turbo 1 is tied to bank 1 (cyl 1, 2, 3) while turbo 2 is tied to bank 2 (cyl 4, 5, 6). The front oxygen sensor being bad causes exactly what you are describing. The replacement is a big job, too. Call me at 205-541-9580 and I'll walk you through the procedure.
Old May 26, 2011 | 06:34 AM
Bimmerguy's Avatar
I had both fronts changed last year and it was indeed quite costly..I will give you a call later today if that's ok? Thanks!
mrlefler999
Mar 8, 2021 02:07 AM
MNWILD
Sep 10, 2020 11:29 AM
ericsb210
Mar 30, 2010 09:43 PM
Sanel30
Feb 18, 2010 09:16 PM
Epr7339
Jan 6, 2007 12:25 PM
