Possessed Door Locks?
Old Apr 9, 2008 | 11:11 AM
worldspeaker's Avatar
Default Possessed Door Locks?
Hi everyone,
I have a 99 S80 that has developed a strange noise everytime a button is pushed tounlock the door, lock the door and open the door. It happens with all the doors and the sound is similar to that horrible buzz that you hear when someone answers a question wrong on a game show. Sometimes it will make the noise to lock it but it doesn't actually lock.
Any ideas?
Dave
Old Apr 9, 2008 | 05:40 PM
Default RE: Possessed Door Locks?
Might be a bad relay.
Old Apr 9, 2008 | 06:06 PM
Do you know where the relay is located?
Old Apr 9, 2008 | 06:12 PM
There is one under the dash.
But also if one of the locks are going bad it might cause the same problem as well.
Or also the door module will do that if going bad.
You might want to have someone pull the codes for the door modules.
Usually only a Volvo specialist can pull them.
Old Apr 9, 2008 | 08:05 PM
The sound seems to only be coming from the drivers side door. Does that mean the door module is the most likely cause?
Old Apr 9, 2008 | 08:09 PM
I would say yes.
But if you have the codes pulled it will tell you for sure.
Also if it needs to be replaced the Dealer will have to download software to make the new one work.
rcvolvo
Jun 3, 2012 02:25 PM
momofyr
Sep 20, 2009 10:40 AM
foxkilo
Apr 2, 2008 09:37 PM
jerryman
May 9, 2006 09:06 PM
850GLT
Sep 8, 2005 01:07 PM
