Rear Brakes - 2008 S80
Old Jul 12, 2010 | 11:55 AM
Slothrot's Avatar
Default Rear Brakes - 2008 S80
Replacing the rear brake pads on my 2008 Volvo S80 and cant seem to be able to compress the piston. Have a caliper tool, but none of the heads fit. Is there a special peice for the Volvo and any idea where I can get it?
Thanks.
Old Jul 12, 2010 | 03:54 PM
mustang's Avatar
I'm not sure how different the 01 is to an 08 but I used a large c-clamp to compress mine. Also is your brake reservoir cap off?
i assume you are doing the following?
http://www.youtube.com/watch?v=Pz2ZkubnZgo
Guessing you know the basics, sorry i'm not much more help.
Kris
Old Jul 12, 2010 | 06:34 PM
SVTfocusO3's Avatar
There should not be any special tools for this, use come channel locks.
Old Apr 9, 2011 | 05:20 PM
yogi89's Avatar
I believe the rear piston has to be rotated clockwise while compressing the piston. I had one of those square cage looking brake tools that a 3/8 extension and ratchet clip into. I had to find a side that was close to the 2 dimples in the piston and grind down the sides of my tool till it fit. It took quite a bit of pressure to get the piston to retreat. They make special tools for this purpose with interchangeable heads for different pistons. Harbor freight sells one set. Also a pneumatic tool is also available.
Salty1
Apr 11, 2013 09:34 AM
robertrudolphi
Oct 30, 2010 10:06 AM
mark107
Oct 20, 2009 10:34 PM
michaelan
Jul 9, 2009 09:45 AM
LIKEAROCK99
May 14, 2008 07:38 PM
