Oil Pump
Old Apr 1, 2011 | 08:40 PM
jaz's Avatar
jaz
Default Oil Pump
I have a s80 and I need a oil pump. I was told that it is comon for the s80 1999. The price to fix it would be aroud 1,400. I was also told that i might still have the issue if I have the work done because if the port holes are clogged there would be no pressure. Then I would need to have the head done and the hole job would then be around 5,000. is that true.
Thanks for the help.
Old Apr 4, 2011 | 05:42 PM
How do they know if the port holes are clogged? What motor is installed in the car? Get the number off the front of the timing belt cover. I think it's the same motor as the S90 or 960's. If that is the case, I would just replace the oil pump and see what happens.
How many miles on the car?
Old Apr 9, 2011 | 08:21 PM
jaz's Avatar
jaz
Default oil pump
Its a 2.9 and 156,00 miles. how hard is it to do myself. I got some skills. thanks
nuclearseal
Aug 17, 2022 01:48 PM
majorcode
Nov 4, 2013 06:41 PM
nuclearseal
May 1, 2013 07:01 PM
endneu913
Nov 21, 2010 10:53 AM
katiejoyful
Dec 12, 2007 04:49 PM
