Rear passenger door lock problem
Old Dec 8, 2009 | 11:48 PM
BrettS80's Avatar
Default Rear passenger door lock problem
So, problem is that when the car is unlocked the rear passenger door will lock when the handle is pulled from the outside instead of opening. Anyone knows what might be causing this and a possible fix?
Old Dec 15, 2009 | 08:18 AM
BrettS80's Avatar
Does anyone know where I can find a diagram/instructions for removing the interior door panels and fixing the lock mechanism?
Update. The door handles on both sides will cause the door to lock. The only way out from the inside is to hold the lock *** (that little thing at the bottom of the window) from the inside up and then pull the handle.
Old Dec 22, 2009 | 10:51 AM
jlewisinsyr's Avatar
Sounds like a computer issue, maybe a setting that was turned on at the dealership. Has it always done this or is it a new issue?
Brouss4
Aug 8, 2014 10:55 PM
J Dubb
Oct 14, 2009 11:58 PM
W35
Apr 29, 2009 09:44 PM
Barnaclebill
Jan 22, 2009 08:03 AM
jonnybobs
May 30, 2008 07:59 AM
