2002 Volvo s80 window Regulator
Old Dec 21, 2009 | 07:08 PM
volvo-man's Avatar
Default 2002 Volvo s80 window Regulator
I have a 2002 Volvo S80 and my driver side window regulator broke. I took it to a body shop who got a new regulator, installed it but then they called me and told me that the window rolls only half way up. They called the dealership who told them that something needs to be reset in order for the window to work properly back again that I need to bring in the car for a diagnosis which will cost a $100.00.
Does anybody know if there is really something that needs to be reset in order for the window to work properly back again?
Thanks
Old Dec 21, 2009 | 10:13 PM
Does it jam up or just stop?
There is usually no programming needed.
Old Dec 22, 2009 | 07:39 AM
vegasjetskier's Avatar
Thanks
Per VADIS, programming is needed to set the limits on the window when a new regulator is installed. Otherwise the regulator doesn't know where to stop the window.
Old Dec 22, 2009 | 06:54 PM
You can set the positions with the window switch itself.
Pull the switch up manually with the switch not Auto all the way to the top and hold it going up for 5 seconds. Then do the same thing going down and that will set the positions.
Veronica Tumavicus
Nov 1, 2017 07:08 AM
mk2sprite
Jun 12, 2014 08:47 PM
reecesp1eces
Feb 2, 2014 08:44 PM
wildcard442
Apr 11, 2010 09:12 PM
aeabston
Oct 29, 2006 11:10 PM
