Reduced enging performance light ??
You need to have the codes pulled.
Could be a bad mass flow sensor.
Could be a bad throttle body.
Could be many things thats why you need to have the codes pulled first.
I as well am receiving a "performance reduced" msg. Looks like there are problems with the throttle body.
http://www.autosafety.org/article.php?scid=119&did=817
Went to pick it up today.( they replaced the fuel pump) but only got 1/2 block before it died again....check engine light stayed on and would not start again....Waiting to hear from the Service Advisor ??? sigh...I love my car...dammit.
1.some 2002 and all 2003 up use a bosch style throttle module unlike 99-02 magneti-merelli throttle modules the bosch has been less problematic. ypur car has the bosch. 03
2. the reduced engine performance light will not come on due to a faulty antenna ring (antenna ring is as prevously stated part of the immobelizer system) an antenna ring will not allow communication from the chip in the key to the ecm to start the car. the reduced engine performance message came on due to an other problem
Not that I am aware of because it is a totaly different system.
The older was a module itself.
The newer style it just the end of the line it just openes and closes according to the voltage it receives.
