Replaced both o2 sensors but still check engine light
Old Jun 29, 2010 | 01:15 AM
tork's Avatar
Default Replaced both o2 sensors but still check engine light
Initially I had codes P0154, and P0157 which indicate Bank 2 sensor 1, and sensor 2 are both suspect. I changed both sensors with Bosch replacements (not generic, but original volvo replacement numbers).
Now the car runs great, but I can't get rid of a P0156 code. The code relates to O2 sensor circuit malfunction on Bank 2 sensor 2. That's the sensor I just replaced!
I've tried the battery disconnect trick, the holding the battery cables together for an hour once the battery had been disconnected, and clearing the codes only to have the check engine light reappear.
Any ideas what I should try next?
Thanks
Old Jun 29, 2010 | 01:16 AM
tork's Avatar
Whoops. That would be a 1999 S80 T6 I'm talking about. 125,000 miles.
Old Jun 29, 2010 | 05:09 PM
andrei3333's Avatar
i had this issue twice, the first time it went away for about a year, the second well i still have it now
my MPG and performance is great so im not gona bother, but there is a problem somewhere. its pretty stupid, never had that on any other car
Old Jun 29, 2010 | 05:41 PM
537playing's Avatar
Could it be that your connection isn't tight enough?
Old Jul 16, 2010 | 11:43 AM
tork's Avatar
Thanks! The connection had come loose on the O2 sensor. All is fantastic now.....
volvos40dude
Nov 19, 2014 09:07 AM
lemmon13168
Aug 31, 2014 01:27 AM
jonqu
Aug 26, 2013 08:31 PM
DrHicks
Dec 9, 2011 11:39 AM
ocean238
Dec 23, 2007 05:43 AM
