S-80 Air intake manifold hose part Identification
Old Aug 10, 2012 | 07:33 PM
yank50's Avatar
Default S-80 Air intake manifold hose part Identification
I have a 2001 S-80 2.9l on turbo that has two ck engine codes , Fuel too lean. I found the following what looks like a check valve in the air intake manifold hose on the left side on the manifold intake. This part has a hole in it and I think that is where I'm sucking in air.
Attached Thumbnails S-80 Air intake manifold hose part Identification-img_0251.jpg
Old Aug 11, 2012 | 08:40 AM
yank50's Avatar
Default Power brake booster check valve
This part is the power brake booster check valve. I had a hole in it which was on the under side of the valve. I had to rotate it to find the hole. I believe that is where the air is being sucked into the intake and is causing my P0171 and p0174 " bank 2 fuel too lean engine codes. I will replace this and report back if that clears the codes.
2001S40nj
Nov 20, 2013 12:52 PM
slowtype
May 4, 2012 06:22 PM
rquinonez32
Sep 30, 2008 02:08 PM
fibzzz
Mar 1, 2008 11:51 PM
volvoami
Jul 19, 2007 12:33 PM
