s80 2.9 oil splatter
Old Jul 23, 2007 | 11:52 AM
theprinceofpersia54's Avatar
Default s80 2.9 oil splatter
my 99 s80 2.9 has weird problems the car has a mind of its own. sometimes when i rip it, i open the hood and oil has jumped all over the engine and intkae(grill piece) and around, the oil pin is poped up and it seems thats where its coming from. what could this be from? another problem is when my brake pedal is fully released i hear air leaking fom somwhere, wheni press the brake it stops. EXTREMELY irritating sound, its like slowly realsing air from a baloon.
Old Jul 23, 2007 | 11:09 PM
Default RE: s80 2.9 oil splatter
someones got to know what this is
Old Jul 25, 2007 | 04:27 PM
gordon368's Avatar
I had the brake pedal problem, where i heard an air noise/ hisssing comming from it....
1.) they bled the breaks, to see if there was air in the system, and that didnt work
Solution: the brake booster/master cylinder had to be replaced.
Old Jul 25, 2007 | 06:11 PM
Sounds like you have 2 problems.
1.Clogged vent box of something in the vent system.
2.Bad brake booster.(causing the noise inside the car)
Old Jul 25, 2007 | 07:49 PM
well the braking is not so bad, i open the panels under the steering wheel and clean the pipe behind the pedal and the sound quiets down for a few months
any one know about the oil?
Old Jul 25, 2007 | 07:56 PM
Like I said above for the oil which you had as your first quiestion sounds like a plugged vent box or hose somehwere.
Old Jul 25, 2007 | 09:45 PM
it only happens when i floor it on hot days
Old Jul 25, 2007 | 11:10 PM
jdevarie's Avatar
As Tech mentioned, a clogged vent box or vent hose somewhere.
Also, the brake booster is on its way out.
my $0.02
Old Jul 27, 2007 | 01:00 AM
so are my brakes going to fail one day? becuase its my moms car and i dont even want to imagine it
Old Jul 27, 2007 | 10:03 PM
Maybe eventually they will fail. The pedal will get really hard.
nuclearseal
Aug 17, 2022 01:48 PM
The Space Monkey
Jul 12, 2017 11:52 PM
endneu913
Nov 21, 2010 10:53 AM
jeannelw
Nov 18, 2005 10:05 PM
witstaffy
Jul 25, 2005 09:31 PM
