S80 hitting fuel cut when WOT
Old Jun 23, 2009 | 06:25 PM
kyvahe's Avatar
Default S80 hitting fuel cut when WOT
I recently changed out one of my ignition coils on my 99 T6 which means I had to take off the intake/plastic turbo pipes.
I double checked and made sure everything is connected and connected tight, but for some reason when I use full throttle i hit fuel cut around 3k rpms.
If I don't use full accel, i can take up the RPMs no problem.
Has anyone had a problem like this before? Is there a possibility i switched up some vacuum hoses when I took them off?
Old Jun 24, 2009 | 03:18 PM
ceepyou's Avatar
Double check your vacuum lines but also look around on this forum. For me, this situation got worse and was because my fuel pump was failing. That was also sudden.
Old Jun 25, 2009 | 08:04 PM
You will only hit fuel cutoff if you are over boosting by way to much.
nebsch
Mar 12, 2012 10:36 AM
Cobra_03
Jan 31, 2009 10:04 AM
03S80D5
Jun 29, 2008 11:37 AM
hispeed
Apr 9, 2008 05:31 PM
