S80 Limp Mode
Old Mar 12, 2013 | 09:43 AM
TJVolvo's Avatar
Default S80 Limp Mode
Hey guys so here is the deal with my S80 T6
Its in Limp Mode,
with Check engine codes P0715 and P0756
These are some of the things i have done
I have changed Both solenoids
i have changed TCM
I have changed the Transmission oil
i have checked fuses
i have disconected abs harness
I have left car disconnected from battery for 24 hours (15 min should have been enough)
Here some other information -
When i use OBDII and erase P codes it comes back on INSTANTLY
does this mean its a wiring problem?
I have spent countless hours trying to figure out the problem i have also bought a ALLDATA packet for the volvo but surprise surprise no help there
Old Mar 12, 2013 | 03:06 PM
75ohm's Avatar
Quick search returned these results:
P0715 - Turbine Shaft Speed Sensor Circuit
P0756 - Shift Solenoid B Performance or Stuck Off
Old Mar 12, 2013 | 03:07 PM
75ohm's Avatar
What year is your vehicle?
Old Mar 14, 2013 | 04:20 AM
martinguptill's Avatar
I probably know this 0715 is an input speed sensor fault. It could be activated by a difficult mistake in cabling, but the indicator itself may go bad as well.
bswarthout
Oct 26, 2009 08:45 AM
deathbots
Jan 1, 2008 02:44 PM
RedTurbo850
Feb 26, 2007 10:22 PM
swede850T
Jul 4, 2005 03:44 PM
