S80 with no power after battery died
Old Mar 27, 2018 | 09:39 AM
Jdsikking's Avatar
Default S80 with no power after battery died
I have a 04 S80 that the battery died in and after recharging the battery I no longer have any electrical in the car. Interior lights, dome lights, etc. Nothing... Any suggestions?
Old Mar 27, 2018 | 08:27 PM
you didn't say if you can start the car. if you have a volt meter check the voltage across the battery terminals. Next is inspect the cables to the battery. clean the posts and retighten, inspect the ground strap etc. If you have 12.6 V at the battery and no interior lights, check for voltage at the fuse box, then check all the fuses.
cambraj@verizon.net
Feb 10, 2021 08:09 AM
geostang
Apr 2, 2014 02:29 PM
makura
Mar 21, 2014 02:49 AM
AzNick
Dec 5, 2008 08:03 PM
theelite
Oct 5, 2008 06:06 PM
