S80 steering wheel replacement
Old Feb 16, 2007 | 07:06 PM
LPG S80's Avatar
Default S80 steering wheel replacement
Hi - I'm thinking of replacing my steering wheel as it's quite worn & I can get one cheaply. Is this a simple job? My S80 is a 1999UK 2.9 SE Auto (non turbo) with cruise control - it's done 136,000 mls.
Also how easy is it to clean the ETM? I've heard it's worth doing on high mileage S80's.
Any help appreciated - thanks.
Old Feb 17, 2007 | 02:37 AM
Default RE: S80 steering wheel replacement
The steering wheel is pretty easy to replace.
You should need a long T-30 bit to loosen the air bad.
Then it is a screw to remove the steering wheel.
But there is a little screw in the steering wheel that needs to go into the SRS contact reel to lock it into place.
Old Feb 17, 2007 | 08:23 AM
LPG S80's Avatar
Thanks Tech - how do I get to the torx? Presumably it's under the central cover but how does that come off?
Is it a hidden screw under the Volvo badge or do I just prise it off carefully?
Also is there any risk of setting the airbag off?
The seller or the steering wheel states itdoesn't come with RTI - what is the RTI?
Thanks for your help
Old Feb 17, 2007 | 11:20 AM
If you look with a small mirror at the back of the steering wheel you should see the holes that you slide the torxes bit into.
RTI is Road Traffic Information.
Old Oct 13, 2007 | 08:01 AM
s80ray's Avatar
a side issue. does the steering wheel have globes in the controls ? are they easy to replace? f so how?? thanks
Old Oct 19, 2007 | 11:05 PM
Volvocars's Avatar
Globes=light bulbs? If so then yes, and if you can remove the steering wheel you can repalce the LED bulbs.
trainlover
Mar 16, 2014 08:48 AM
1chevelle
Apr 20, 2013 07:23 AM
taylormaed
Feb 13, 2013 08:05 AM
nehopsa
Jun 24, 2008 11:20 AM
