s80 t6 awd conversion, can i use xc90 transmission?
i have a 1999 s80 t6. i see that we all have the 4t65e transmission. browsing the internet the other day i had come across a 4t65e awd from a 2004 xc90 t6. seeing these two transmissions carry the same id number im thinking this xc90 transmission should fit because both transmissions sit in the same place. furthermore im curious to know if the s80 awd t5 uses the same subframe and rear diff and if it has the same gearing or would i have to get a xc90 rear end and subframe as well . im sure i need the gas tank and all these other little things but in the grand scheme i think it may work. let me know how you feel.
if you wonder why? what good is 300hp to the front wheels? thats my problem. and when i build the transmission im looking for 400 to the wheels. front wheel drive is not on my agenda plan. thank you for your time
You're probably just going to have to try it and see. I don't think a lot of people are spending that kind of time and money into an old S80. There's more than just the trans and differential. The DEM is what controls the AWD and it has to communicate in the network. Honestly, it's just not worth it.
