squeaking noise
Old May 30, 2008 | 12:26 AM
yu21's Avatar
Default squeaking noise
I just got my timing belt and accessory belt replaced.
Before I got them replaced, my car was making a squeaking noise from the left side of the engine bay and I thought it was the accessory belt.
However, the noise is still there for some reason and its driving me crazy!!!!!!!
What could be causing the noise??
Old May 30, 2008 | 05:56 PM
Default RE: squeaking noise
When you say left side is that when you are looking under the hood?
Drivers side or passenger side?
Old Jun 5, 2008 | 01:06 AM
yu21's Avatar
it was the passenger side
the noise becomes more frequent as i rev
Old Jun 7, 2008 | 08:14 AM
It could be a bad bearing in the Alternator or A/C compressor.
Best way to find out is to remove the accessory belt and spin the pulleys and listen for the noise.
Old Jul 29, 2008 | 09:47 PM
Chexjc's Avatar
I found the source of a squeaking noise that I had for a LONG time: The glove compartment handle.
Old Jul 30, 2008 | 01:44 AM
fs's Avatar
fs
ORIGINAL: tech
This works good for pin-pointing noises.....Take a wooden handle from something..place one end on car part/power steering pump/alt/valve cover......the other end on your ear.....good way to pin-point things....just be careful of moving parts.
Old Jul 30, 2008 | 06:57 AM
bigern45's Avatar
i agree with tech.. remove the belts and go ahead and start your car. if the squeak goes away then you know it has to be a belt or something driven by the belt. then check for play in the bearings of different components if the noise does go away. or a bad bearing noise, you may not have play in it just yet.
volv0850
Mar 5, 2015 11:55 PM
tahafisaka6
Aug 29, 2011 10:03 AM
Steamroll9
Feb 16, 2006 11:55 AM
900 Aero
Sep 13, 2005 09:39 PM
rp850
Jul 27, 2005 12:45 AM
