Steeering
Old Oct 24, 2006 | 04:44 PM
gordon368's Avatar
Default Steeering
My steering wheel is gettin harder and harder to turn.....
like for instance, if i take a turn about 10- 20 mph like a 90 degree turn or "u-turn" the steering wheel gets hard to turn...
if i turn it sometimes i hear it creaking.....
any ideas?
Old Oct 24, 2006 | 09:20 PM
studd34000's Avatar
Default RE: Steeering
your power steering pump is going or you need fluid
Old Oct 24, 2006 | 11:34 PM
gordon368's Avatar
I think the fluid is a little less than half, so maybe the pump?
At start up everything works fine and then as im driving it feels like its stiffening up...
Old Oct 25, 2006 | 12:57 AM
master_pre's Avatar
The steering system is sealed, you shouldn't be losing fluid. You need to get that checked out, hopefully it's just the pump.
Old Oct 25, 2006 | 03:14 AM
gordon368's Avatar
The power steering tank was leaking before, they replaced the tank, might be leaking again?
Old Oct 25, 2006 | 11:29 AM
master_pre's Avatar
That could be a possibility. Do you know where the tank is located?
Old Oct 26, 2006 | 01:01 AM
gordon368's Avatar
yah its located just below the coolant tank? Its black in color....
Old Oct 26, 2006 | 11:15 AM
master_pre's Avatar
Good, have you noticed any fluid puddles near the pump?
Old Oct 26, 2006 | 09:10 PM
gordon368's Avatar
have seen no puddles...
Old Oct 27, 2006 | 02:18 AM
master_pre's Avatar
Huh?!? I had my steering go out in my Grand Prix and it ended up being quite a mess$$$$$. The way it was explained to me by the mechanic is that the steering system is sealed so there should be little to none in regards to fluid loss. Have you tried refilling the fluid and then monitoring to see whether or not you are still losing any?
Old Oct 28, 2006 | 07:10 PM
Could be the steering rack going bad.
Old Oct 29, 2006 | 10:41 AM
Ihatespeedbumps's Avatar
Starting to sound like your going to need a whole power steering rack.
Old Oct 29, 2006 | 01:53 PM
gordon368's Avatar
is that the so called "rack and pinion" repair?
Old Oct 29, 2006 | 09:22 PM
master_pre's Avatar
Yep. I would make sure it's not something smaller first. Get the steering system inspected so you know exactly what the issue is.
Old Oct 30, 2006 | 08:32 PM
gordon368's Avatar
it turned out to be a leaking power steering tank.. and i was under warranty.
Old Oct 31, 2006 | 01:01 AM
master_pre's Avatar
That's great news man! You wanna talk about a perfect scenario!
kzs983
Mar 3, 2014 01:02 PM
oldvolvonut
Mar 29, 2011 09:36 AM
