S80 mystery bulb....
Old Oct 30, 2006 | 08:51 PM
profcharlie's Avatar
Default S80 mystery bulb....
OK, I give up - as you face the headlight assembly, about 11 o'clock in the high beam assembly is a small bulb--what purpose does this serve????
Old Oct 31, 2006 | 03:52 AM
althej's Avatar
Default RE: S80 mystery bulb....
Hey whats up, I wish I had your headlights,ive been wanting to know what year and models they came on.......
WHat year is yours? Thats called an LED light i think there is no general purpose, they are just for looks, or you can change the buld color and will look a lot nicer....
Or you if you want illegal hook up a strobe light since everything is predrilled. i would probably do that.... hope i was any help
Old Oct 31, 2006 | 04:38 AM
gordon368's Avatar
i think they come on when u hit the yellow button on ur remote to illuminate the front end of the car, the yellow button on the remote in general ilumminates the entire car. Also I notice they are on just a little bit when having the headlights in the off position.....
Old Oct 31, 2006 | 11:13 AM
master_pre's Avatar
Have you checked the owners manual? I'm at work and don't have mine on me but that may explain what the light is for. Gordon368's explaination sounds about right.
Old Oct 31, 2006 | 03:02 PM
billofdurham's Avatar
Approach lighting
When approaching the car at night, press the yellow button in the central locking remote control. This lights up the interior courtesy light, parking lights, license plate lights and the lights in the sideview mirrors.
Old Nov 1, 2006 | 01:47 AM
Thanks to all who responded- tried the yellow button, owner's manual is silent on the issue --again, as one faces the front of the vehicle, on the passenger side in the high beam assembly at 1:00, and the driver's side in the high beam assembly at 11:00 are single small bulbs-removed each bulb and checked, each bulb is not burned out--simply cannot figure out what purpose they serve or how they become active--is this just one of those mysteries ?? They must have some purpose..........HELP---
Old Nov 1, 2006 | 04:11 PM
pcgold's Avatar
I'm not sure of the purpose, but in Canada, with daytime running lights, they are on all the time - in addition to everyo ther light on the car.
Also, a few weeks ago, I posted this:
https://volvoforums.com/m_43328/tm.htm
I have yet to find a w5w bulb. They are available in Europe. I've also done some other internet research because I was going to replace them with LED bulbs. However, everything I've read states that you cannot put an LED bulb into a headlight housing. LED bulbs cannot stand the heat generated inside of a headlight housing.
Other research would lend me to believe that a w5w bulb is the same as a T10 or 501 bulb.
The Sylvania website doesn't help either. Numerous auto parts stores where I live tend to look at me as if I've dropped from another planet when I ask about this bulb.
Has anybody else changed this bulb and what have you used?
Old Nov 1, 2006 | 08:16 PM
studd34000's Avatar
yeah they are part of the out side curtesy lights on an 03 and newer. i know if you were to replace the lights it will some with them but how ever i do not know how to hook them up.
davej
Apr 22, 2011 08:47 AM
2005s60
Jan 19, 2011 01:50 PM
rsylvester07
Aug 12, 2010 12:12 PM
dads 740 turbo
Oct 24, 2008 06:54 PM
nitrodog
Feb 1, 2008 06:25 PM
