struts
Old Feb 27, 2006 | 03:23 PM
robretpd's Avatar
Default struts
99 S80, had a noise from right front, the Volvo dealer says the front right strut and spring seat needs to be changed, it is covered under the extended warranty. Question is, will replacing only one side strut be ok, or do you need to replace them in pairs for the front?
Old Feb 27, 2006 | 07:55 PM
reg's Avatar
reg
Default RE: struts
You never change just one side brakes..............conversely you never change just one side's springs/struts.
Reg
Old Feb 27, 2006 | 09:34 PM
Default RE: struts
ORIGINAL: reg
Reg
AGREED!!!!
Old Feb 27, 2006 | 11:07 PM
reg's Avatar
reg
Default RE: struts
I'll be TECH that if this was not a warranty job the dealer would never ever suggest simply changing one side! It's amazing sometimes!
Reg
ORIGINAL: tech
ORIGINAL: reg
Reg
AGREED!!!!
Old Feb 28, 2006 | 09:01 AM
robretpd's Avatar
Default RE: struts
I will call this morning to see if they changed both sides, I know the guy told my wife when she called to see if the car was ready they were doing an alignment.
Old Feb 28, 2006 | 09:20 AM
gordon368's Avatar
Default RE: struts
because i was under the warranty after I bought a car, they only replaced 3, do I say that to them that they have to replace the forth of something...the question is will it be under warranty? when i back out of my driveway i can hear a bunch of springs go off with an echoing noise....DO i use the brake excuse thing? it doesnt really sound sensible to say to a volvo service representative at a delearship! lol
Old Feb 28, 2006 | 11:18 AM
robretpd's Avatar
Default RE: struts
well its is official, I called and they only did one side, said that the warranty would not cover both as only one side was leaking. They said that as long as no gas from the other side it is fine.
Old Feb 28, 2006 | 08:55 PM
Default RE: struts
THAT IS WARRANTY FOR YOU!!!
Old Feb 28, 2006 | 10:36 PM
reg's Avatar
reg
Default RE: struts
Take a measuring tape and see if one side is higher/lower than the other. If there is a difference, argue the safety side...........
It is pure hogwash to change but one side!!
Reg
Old Feb 28, 2006 | 10:40 PM
Default RE: struts
ORIGINAL: reg
Reg
Agreed!!!
Porschenut
Apr 30, 2014 09:20 AM
gbf1
Aug 17, 2007 02:09 PM
rejeep
Oct 16, 2005 12:47 AM
ray hummell
Sep 30, 2005 09:22 PM
floryed
Sep 5, 2005 01:58 PM
