Susp noise
Old Jul 27, 2006 | 07:37 PM
jerryman's Avatar
Default Susp noise
I have a front creek sound when I hit bumps and give the car gas from a dead stop. First started only doing it when I made a left turn and only on the left side. Then the right side started making a bit of the same noise, not as bad. But now, any major bump in the road gives out a creek/pop sound. Car drives fine, no vibs, had the stab arms replaced, does it sound like ball joints going bad?
Old Jul 28, 2006 | 12:13 AM
Default RE: Susp noise
Could be Bad Sway Bar links, Upper spring seats, Or Balljionts.
Old Jul 28, 2006 | 12:18 PM
familyman's Avatar
I had a similiar problem and it was the upper spring seats
Old Aug 13, 2006 | 12:00 AM
master_pre's Avatar
I need a littel clarification on this topic. I have a creek noise coming from my front drivers side area when I go over speed bumps. It's not loud at all and I barely even noticed it. Is it not good if there is any creek noise, or is it only bad when it's loud?
Oh yeah, I did that suspension test and the best I could tell is that when pressure was applied the suspension went down and came straight back up.
Old Sep 26, 2006 | 09:35 PM
jerryman's Avatar
Funny thing, the Sway Bar links, Upper spring seats have been replaced. The noise is still there. when I push the struts up and down, they work fine, push down, then comes back up.
No noise unless car is moving. I have tried boucing it up and down, pushing it side-ways, jacking it up and dropping it fast.
NO NOISE.. But get in the car and move it 5 feet and hit a small bump, creek-pop. sounds just like the old ball-joint problem on a 1967 camero, except, I can sit all day long at a stand still, moving the wheel back and forth, no noise. Even took it to a mechanic, he heard the noise while driving, but just like me, couldn't isolate it at a stand still. He could not find where the noise came from and gave me the car back.
HELP HELP HELP!!! anyone have even a clue.
Should I just start changing parts?
If I put in new complete struts, how do I need to compress the spring?
Old Sep 26, 2006 | 10:17 PM
That would be my next guess is the strut.
You will need a GOOD spring compressor to compress the spring to replace the strut.
http://aolsearch.aol.com/aol/imageDe...ype%3DimageTab
Something like these.
TheTrainwreck
Mar 10, 2011 04:31 PM
chimmychong
Apr 2, 2008 08:39 AM
ludeless
Aug 28, 2007 07:14 PM
DR54
Jun 1, 2007 12:48 PM
y2blade
Suspension
Oct 23, 2005 03:54 PM
