Tpms
Old Feb 27, 2013 | 08:00 PM
carlsson's Avatar
Default Tpms
Hello:
recently had the tires rotated and during the rotation one of the valves were broken on the tire so it had to be replaced witha rubber valve stem. Discount ordered a new one and isntalled it and now weeks gone by without the light going out saying the tire pressure monitoring needs servicing. Any ideas? Discount is paying for Volvo to look at it, and it may seem that you have to use Volvo sensors?
Thanks
C
Old Feb 27, 2013 | 09:16 PM
ES6T's Avatar
Yeah, you need to use Volvo sensors and you need to have Volvo initialize the new one to the car.
Old Feb 27, 2013 | 09:44 PM
carlsson's Avatar
Thanks! I figured as much, I have always owned foreign cars and it seems sometimes only OEM parts are the only ones that work. Discount didn't know what to do- had me go in verify pressure etc, replace another sensor. so now they are paying for Volvo to look at the issue - which about a week ago Volvo told me it was a software update. After the software update the light did go off but came back on after 20 miles. So I called them and they said they would order new sensors. This dealer seems really secretive about what is going on, so I thought that I would ask the forum to see if anyone had experience with this. I am going in on Friday - hopefully its the sensors since I am out of warranty.
Old Feb 27, 2013 | 10:02 PM
ES6T's Avatar
Did you tell them what happened? If you told them one broke and was replaced with a normal stem, it should be pretty simple- it needs a sensor. Not sure why they would dona software update, there are no bulletins about that that I am aware of.
Old Feb 28, 2013 | 10:50 AM
carlsson's Avatar
Yes I did - on my Volvo App there is a recall for the issue I assumed they loaded that software.
Old May 8, 2013 | 11:38 AM
KFZ's Avatar
KFZ
Default Kfz
I had all four valve stem/sensors on my 2009 S 80 fail before 48 months. The first failure came at 51,000 miles and caused what I thought at the time was a tire blow out. Upon changing the tire, the stem fell inside the wheel. The tire was ruined, and the local Michelin dealer said they are seeing this quite frequently, where the stem locking nut corrodes away causing the failure. Since this happened at 51,000 miles, both Volvo and the dealer (Evans Motors of Dayton), quickly danced away from covering under warranty. Anyone else seeing this kind of safety defect?
Old May 8, 2013 | 01:34 PM
akabond's Avatar
wow ..you should contact volvo company and notify NHTSA immediately
Old May 8, 2013 | 06:41 PM
carlsson's Avatar
When I had the problem it was around 53K miles -
With my issues since the alert would not go off Discount paid for my stems to be replaced with Volvo sensors, after some after markets did not work.
FredRydr
Nov 13, 2016 06:32 AM
garydrenk
Sep 18, 2010 12:05 PM
garydrenk
Sep 18, 2010 12:02 PM
garydrenk
Sep 18, 2010 11:57 AM
fstrdr
Dec 4, 2008 10:01 AM
