Transmission
Old Oct 24, 2007 | 12:51 PM
nce55's Avatar
Default Transmission
I recently bought a used 2001 S80 (80k miles). Two weeks later the transmisson light came on. I brought it to a shop that specializes in Saabs/Volvo's. He said this transmission has an internal defect that it destroys solenoids. Even if I had it repaired, it would happen again. I then took it to a very reputable transmission shop. They said that was nonsense. It is a GM transmission and the can fix it and warranty it for one year. Please - anyone know anything?
Thank you
Old Oct 24, 2007 | 05:52 PM
Default RE: Transmission
Yes it is a GM transmission.
But I would like to know what codes were in the module.
Old Oct 24, 2007 | 08:42 PM
nce55's Avatar
not sure - he just said a soleniod was burned out. Something about the tolerances were machined incorectly and would result in another ruined solenoid if I had it replaced.
Old Oct 24, 2007 | 08:56 PM
felipe's Avatar
My solnoid on my S80 needs to be replaced or there a reset button that needs to be hit. Does anyone know about this. how can I replace the solenoid is it hard.
Old Oct 24, 2007 | 08:58 PM
felipe's Avatar
Is there various types of solenoids the diagnisic test said a need a performance ckt shift solenoid.
Old Oct 25, 2007 | 07:08 PM
If I had the code I could help a little more.
Old Oct 25, 2007 | 07:15 PM
nce55's Avatar
The transmission shop said they rebuilt the transmission. Burned up clutches. I am going to pick it up tomorrow. I will get the full scoop then. He did say that they have fixed scores of this type transmission and nothing suprising.
Old Oct 26, 2007 | 04:55 PM
nce55's Avatar
The code are as follows: TCM000C - shift solenoid S2 hydraulic fault
EMC 510F - vehicle speed sensor
EMC 902A - communication fault with throttle unit
EMC 903A - Throttle position signal missing
EMC912A - Communication with ECM missing
ABS0093 - control module communication
Is it true that Volvo is warrantee the throtle module?
Thank you
Old Oct 26, 2007 | 07:36 PM
Yes the throttle body should be warranty.
The bad part is you have a bad ABS module which messes up communication with the ECM and the TCM.
That might throw the shift soleniod code as well.
Old Oct 26, 2007 | 09:50 PM
nce55's Avatar
Tech - Thank you very much. The transmission was overhauled today and now runs fine. Is it safe to have my ABS mod either rebuilt or buy a reconditioned one from Canada? Either way I have to install myself.
Old Oct 26, 2007 | 11:43 PM
Yes it is safe.
http://home.earthlink.net/~vicrocha/...vo_V70_ABS.htm
Not sure where he is might be worth checking.
Old Oct 27, 2007 | 07:51 AM
nce55's Avatar
Thank you
Old Oct 27, 2007 | 08:04 AM
Your Welcome!
mason3325
Dec 22, 2021 12:51 PM
jeffrisley
Jun 14, 2015 01:48 PM
